Need swap info
1jasonmoody1
9
Soldotna Alaska
So I have a motor from a 94 Ford explorer automatic and I need to know if it can go into a 96 Ford ranger 5 speed both motors are 4.0 liter I already plan on rebuilding the explorer motor before putting it in so if it will work anybody know what I need
Josh B
1,987
Oklahoma
Haha, I'll be swapping a 96 Explorer to a 93 Ranger. I cannot recall all the details, you will have a more complete answer soon I expect.
Best of my knowledge it works well enough up to the intakes, and from there you'll need extensive rewiring or use the old intakes to match your harness
rusty ol ranger
2.9 Mafia-Don
7,590
Michigan
177 CID
Biggest thing will be wireing and ECM. 94 is EEC IV (OBDI) 96 is OBD II
1jasonmoody1
9
Soldotna Alaska
Will I have that problem if I plan on taking the intake off the 96 and put it on the 94 motor all I plan on swapping is the block heads after I do the rebuild
rusty ol ranger
2.9 Mafia-Don
7,590
Michigan
177 CID
The parts will interchange for sure. But im not sure if the sensors are different or in different spots or whatever. Ive never done nothing to a newer 4.0 besides change oil lol.
sd359
Law Enforcement
6
Rocky Mount, Va
The 94 doesn't have a cam sensor and I think the 97 does.
SenorNoob
584
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
In 95 there were changes in the head. Apparently to get the O2 sensor working faster. I've heard that using the newer heads with an older computer will significantly shorten the life of the engine. Not sure how it would play out in reverse.
Seems to me as long as you used the 96 intake, injectors, sensor, and wiring harness on the 94 engine it'd be fine.
