Need some help
spanky50
Law Enforcement
6
muncie,in
ford ranger XLT
4" rough country
32" cooper STT
I have a 97 ranger XLT 4x4 4.0
Just put a new engine in my truck. The old had a little miss before that engine blew up. I was hoping that when in put the new engine in that it would take care of it but it's still their. I'm not sure where to look now any help would be appreciated.
Gary DuBois
119
Puyallup Washington
245 cubic inch
31 inch
I would check these first and maybe it will fix your miss problem - Faulty spark plugs or wires. Faulty ignition coil. Broken piston rings
ekrampitzjr
1,077
Virginia
This. Are the wires on the right plugs? Are they in the right spots on the coil pack? Are they fully seated at both ends?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Are you sure its not just the standard 4.0 tick that goes away when its warm?
Josh B
1,986
Oklahoma
Did you install the engine? If yes, check post #2 & #3.
Exactly how "little" is "small" enough to blow an engine?
Josh B
1,986
Oklahoma
I think you may well find it in that coil pack hook-up, it is SOOO easy to get that mixed up it is unreal.
Good luck with it man
spanky50
Law Enforcement
6
muncie,in
ford ranger XLT
4" rough country
32" cooper STT
Just put a new engine in my truck. The old had a little miss before that engine blew up. I was hoping that when in put the new engine in that it would take care of it but it's still their. I'm not sure where to look now any help would be appreciated. It idles ruff in gear when you come to a stop if you don't 2foot it to keep it running. It seems to run fine as your driving. as soon as you stop it wa
The miss is not what blew the engine my foot did lol
rusty ol ranger
2.9 Mafia-Don
7,581
Michigan
177 CID
Cylinders need 3 things to pop.
Fuel, spark (at the right time) and compression.
Check those things and go from there.
spanky50
Law Enforcement
6
muncie,in
ford ranger XLT
4" rough country
32" cooper STT
I thank I found it EGR tube had hole it. Started smoothing out after I fix it.
Thanks for the help
