eric
- Jan 14, 2009
- 0
check engine light is on and code says p1537. I believe that is the IMRC. I ran the truck for a while without changing plugs and when I did , they were pretty worn out. Would this cause excess carbon build up in the manifold that can be cleaned out with brake cleaner? I was thinking of spraying out whole manifold including sensors to see if that fixes problem. Mechanic did look for vacuum leaks and could not find any.
Your thoughts please
thanks in advance
thanks in advance
