ranger_gord
- Feb 8, 2008
- Reaction score
- 11
- Location
- Canada
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L
- Manual
- 2WD / 4WD
- 4WD
- Tire Size
- 31 10.5 R15
- My credo
- 40 yr. Electronic/electrical mechanical technician¤tly a forensic engineer,Fire Investigator
Hi all,
I am sorry to post this here, but I dropped the transmission/case to replace the concentric slave cylinder and check things out. 4th gear was a bit noisy and a little “challenging,” noisy to engage, after getting it back from a “moving experience.” Preliminary examination shows at oil drain plug, 2 metal gear pieces, insert key,and a piece of synchronizing blocking spring stuck to the magnet. Removed the upper shift assembly and found 4th gear synchronizer missing pieces.
I need to replace it and refresh the tranny. Any advice on a good supplier of parts to Canada?
If I need to repost this in another area please let me know.
Thank you.
R_Gord
Thank you.
R_Gord
