need help with 5.38s in a d44
xkotyx
20
Waynesboro, VA
this thing has had me running in circles. we finally got everything put together and the ring is barely touching the pinion! so we shim it all the way over as far as we can, and its still barely even catching the tooth. its like the ring still needs to come towards the pinion another 1/16-1/8", maybe even 1/4"!!!!
we are completely bumfuzzled. can anyone give me any insite?
pimtool
prosperity,SC
Did u use the carrier for 3.92 gears and up?
xkotyx
20
Waynesboro, VA
do you have to have another carrier for 3.92 and up?
yep i guess i do need a new carrier.... if i just get the bare 3.92+ carrier case, will the shaft and spider gears from my 3.72 case work, or do i have to get everything new??
pimtool
prosperity,SC
I believe so, when I was looking at 5.13s for a d44 , it said for use with 3.92 up carrier. so it must be a thicker mounting surface or something.
Im not the expert, but thats were I would start looking.
good luck.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yes you need the different carrier OR a ring a pinion set that has a thick ring gear.
xkotyx
20
Waynesboro, VA
will my spider gears and shaft from my 3.72- carrier work on a 3.92+ carrier? or do i have to get a carrier with the guts too?
yostyexplorer94
South Central, Pa
Solid Axle Swap 4x4
Your spider gears should work in the 3.92 up case. It worked in mine
xkotyx
20
Waynesboro, VA
thanks guys! just ordered it!
No members online now.
