89fordranger2021
- Feb 25, 2021
- 0
- ohio
- ford ranger
Hello group,
I need some help and would be appreciated, I'm going to try to be detailed as much as possible. Well, let's get started.
I went out and bought a 2005 Ford Ranger 4.0L SOHC V6 4x4 County truck, the cam and head had badly been thru Hell, so I pulled out the 4.0 SOHC Engine and dropped in a 1998 Ford Ranger 4.0L OHV, when everything was reinstalled. I used the 4.0 sohc harness from the engine and reinstalled on the 4.0 OHV engine. I had to use the engine computer that was used with the OHV engine. I did have to re-pin the ecu plug. When I pulled the sohc computer out the odometer stopped working. So far everything in the truck works. It runs really well, and shifts well. So I do a full Diagnostics on the truck. Codes from the ecu comes up as P0500 VSS, and that's it. I have done diagnostics on the ABS system and working like it should. No other codes come up on the truck. I need help to find out how to get the odometer working right now. It's shifting on the output speed sensor on the transmission.
Help would be great!! I have a ton of time and money in it. Thanks.
