- Jun 2, 2012
- 8,374
- canada
- Ford
Instead of "hitting the inertia switch", turn key on, press gas pedal to the floor and hold it there, this will turn off the injectors while cranking.
It is a routine in all EFI computers to clear a flooded engine.
If computer is on(key on), and there is no pulse from CKP(crank position) sensor, and it gets 4.5v, or higher from TPS sensor(pedal to the floor) it will disable grounding for fuel injection.
If fuel pump is coming on then EEC relay is closing so engine electrics should all be working.
So I doubt it would be a harness issue.
Did you test the spark?
Do you have an old timing light so you can check if #1 is sparking at TDC mark?
While the CPS is important, it only times fuel injectors after startup and some spark advance functions, the CKP sensor is the important one, it starts and times spark and injectors for startup.
Engine will start and run without CPS pulses.
So test for spark, if you have spark CKP sensor is working, because you have fuel on the plugs it is also most likely working
