- Aug 6, 2007
- Reaction score
- 1,793
- Location
- Macon/Fort Valley, GA
- Make / Model
- Ford
- Engine Type
- V8
- Automatic
- 2WD / 4WD
- 4WD
As of right now the NA build comes first, but I don't want to forget about that end goal of 2.3 turbo. To that end I'm biasing time and money towards improvements that will also be beneficial for the turbo motor.
At this time the list of planned improvements for the naturally aspirated engine are below and pretty much in the order I intend to do them:
I think the lists are pretty self explanitory, but I'll be happy to explain my reasoning for any of them. Nearly everything on these lists are beneficial for both the NA and Turbo build. The exceptions are the NA camshaft, header, and thinner headgasket.
I'm not too sure about the later model factory header, I haven't paid attention to what's on the truck now. It seems like a relatively inexpensive upgrade that will help take advantage of better cam and later porting.
In a previous post I promised more about the ECU situation and here it is. I'm not going to use Moates Quarterhorse, MegaSquirt or MicroSquirt ECU.
Ok that's not entirely accurate. I will be using PiMP EMS which is MS based, and potentially use MicroSquirt TCU to control a transmission. PiMP is a MegaSquirt 3 attached to an adapter board in an EEC-IV style case, that is designed to be nearly plug-n-play compatable with a Ford 60 pin engine harness and fit in the factory ECU location. There are three versions; the "x" which is a basic batch fire EFI system and works with stock injectors, the"xs" that adds sequential injection (but still batch fire capable) and requires high impedence injectors, and the "xshift" that is the same as an "xs" but adds a built in MicroSquirt module for transmission control.
The old DIY MS units are a thing of the past, it seems that now they are all pre assembled. Those systems start at around $650 for the MS3 and shoot up to $1500 plus for a MS3Pro, for either of them I'd have to build out my own engine harness. PiMP (MS3 based) starts around $820 and plugs into the factory wiring harness and mounts in the factory location. The "x" is $820, the "xs" is $950, and the "xshift" is $1400.
Since I will not need the transmission controller features for the A4LD, I am planning to go with the "xs" to gain the capability for sequential injection. That will require replacing the injectors with high impedence injectors, but I figure after 30+ years it could probably stand new ones anyway.
There is one drawback to not selecting the "xshift" and that is the function I don't currently need. It's not officially supported yet, but the 4R44E was added to the latest beta version of the TCU firmware for MicroSquirt. That carries over to the PiMPxshift since it uses microsquirt for the trans controls. Since the 4R44E was found behind the 2.3 and 2.5L in later Rangers, I can bolt it in place of the A4LD in my earlier Ranger giving me full electronic control of the transmission through PiMP. Since the transmission is not officially supported yet I'm not sure it's worth spending the additional $450 on it and I can always add the feature with a microsquirt TCU tied into the canbus at a later time. The biggest advantage on having it built in would be simplicity of it all being in one unit, but I'd have to custom wire it through the expansion port either way.
As for using the A4LD. I plan to have it upgraded well before I even reach the 200 hp mark. At 37 years old and unknown history, I can't imagine a Ford automatic overdrive transmission not being nearly ready for a rebuild/overhaul. The stronger guts of a 5R55E will fit into the A4LD and there is a build guide over on Explorer-Forum for doing that and other upgrades. I intend to follow this guide with oversight from an experienced transmission guy and personal friend or buy a prebuilt unit from PATC that is built similarly and then some. Same stuff could be done on the 4R44E. After the upgrades it should handle anything I'm planning to throw at it. If it doesn't, hopefull it'll go out with a bang not a whimper and I'll reconsider a 5 speed swap.
- #1, before anything else, GET IT RUNNING
- Larger radiator (need one anyway)
- Roller cam upgrade, possibly an aftermarket NA roller cam
- Adjustable cam gear while I'm in there
- ECU upgrade
- Injector replacement
- Later model factory "header"
- Head work, porting and maybe larger valves
- Intake porting
- Thinner MLS cometic headgasket <for a slight bump in compression, but only if replacement is necessary>
- Distributorless Ignition, coil-near-plug <just cause>
- Sequential Injection <just cause>
- Performance transmission upgrade/rebuild or swap <when/if needed & just cause>
- Electric fans <just cause>
