Buggyman
- Dec 1, 2007
- 0
- Ford
- Engine Size
- 3.0 V6
Just replaced the head gaskets on this 2000 3.0, everything ran fine and noticed no leaks while running distilled water through the cooling system, I then added some Zerex flush solution and let it circulate for about 30 minutes then drained and flushed about 5 times with distilled water trying to get all the crud out. I noticed during one of my flushes this small leak on the block, I cannot tell where its coming from, it appears to be behind the water pump, below where the head meets with the block and looks like it originates where one of the water pump bolts goes into the timing chain cover. I tried to tighten that bolt and the surrounding ones down slightly more but it still slowly leaks. No leaks are visible when the truck is started, I have checked both while the motor is cold and hot. Any ideas? I do not feel like its the head gasket because its dry around the head gasket, I don't think its the water pump because its behind it, only thing I am not sure of is the lower intake gasket. I torqued everything to spec, used RTV where required and double checked my torque before putting it back together. Also, I had the water pump out for part of the head gasket job and I replaced the water pump gasket, used RTV sealant on both sides of the gasket and used a little sealant on the threads of the long bolts, I have been keeping an eye on the oil condition and so far no signs of H20.
Thanks for any ideas, sorry about the bad picture quality, I had the pictures rotated on the computer to show up/down but the site flipped them back, hopefully it gives the idea of where its leaking.
Philip
Philip
