For some reason blowers aren't common on 4-stroke diesels. I think the V903 in the Marine's Amtracs had a roots blower and a turbo on them in one version. I think that there is so much exhaust coming out it's just a no brainer to capture that instead of adding the complication and drag of a blower. A turbo and a diesel just belong together. But if you can get it on then use a 10-15psi blow-off valve and keep the fuel down enough to not exceed 1,100F EGT. The 6.9/7.3 is a physically tougher engine, but they use the same injection pump and when they are turbo-supercharged can both burn up all the fuel that pump can give out and so make the same power and torque. The 6.2 will come apart before the 7.3 would though, no question. But I downshift when the EGT goes over 1,000F and go as fast as I want. The torque makes the heat so when you downshift and use the gears for torque it cools it right down and you don't really trade anything off.
I have a 1988-2000 body-style turbo kit. What is the 6.2 in?
