My 4.0 swap
BlackBII
Ranger Custom
Truck of Month
984
UT
There are normally threaded holes on the back of the heads and tops of the exhaust manifolds. I always use those. Just put a bolt through the chain and thread it into the hole. One on the back of the motor, one on the front, opposite sides of course.
AZFX4
Arizona
FORD
2.9
Well I finally got around to getting the B2 in the garage and getting the motor and drive train. Here are a few pics of the old dying 2.9 coming out.
Getting started
These are a life saver!
OUT!
4.0B2
151
Walls, MS
4.0 v6
man how i don't miss that 2.9..... just wait till you have the 4.0 in and drive it one time. i can sit here and tell you how great it is all day, but until you drive it-- you won't understand!
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
+1000
I can't wait to get my 5 speed in and get mine backon the road.
AZFX4
Arizona
FORD
2.9
Well tomorrow im gonna unload the explorer and pull it in next to the B2 so I can start looking at what all I need to swap. Then hopefully saturday ill have the 4.0 out of it and get it ready to go in the bronco.
BlackBII
Ranger Custom
Truck of Month
984
UT
What you need to swap?
Everything. :icon_thumby:
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Doo eet! I can't agree more with 4.0B2 there.
AZFX4
Arizona
FORD
2.9
The one question I have is a bout the harness and computer. I see that on the driver side there is a cannon plug the ties the engine harness to the dash but this harness also goes through the firewall on the passenger side too. Anyone know what im supposed to do here? Also where is the computer?
BlackBII
Ranger Custom
Truck of Month
984
UT
Unplug your current cannon plug, and everything connected to it. Pull out your current computer along with the harness connected to it, through the firewall. After doing this, there shouldn't be any wiring left under the hood.
Replace what you just took out with whats in your donor.
disciplerocks
53
Evansville, IN
You are swapping all the wiring and the dash? I just spliced mine.
AZFX4
Arizona
FORD
2.9
Nope not swapping the dash (for now) But im going from a 90 to a 91 so everything should just plug in (so im told). So the harness that goes through the firewall on the passenger side is going to the computer?
disciplerocks
53
Evansville, IN
Then you shouldn't need to mess with the cannon plug. Just unplug the engine harness from the headlight harness on the drivers fender well.
AZFX4
Arizona
FORD
2.9
Ok no one has answered me yet. The harness that goes through the PASSENGER side firewall goes to what? Also I dont see how I can use my existing engine harness if this is a different engine. Why not unplug the cannon plug where it comes through the drivers side firewall and replace the whole thing?
disciplerocks
53
Evansville, IN
Because you dont need to. Its easier to just unplug the engine harness, but you do it how you want.
The harness going into the passenger firewall goes to the ecu.
AZFX4
Arizona
FORD
2.9
Ok I think i see what your saying now. I will probably end up doing all of it since the wiring from my B2 is very brittle and all the connectors are falling apart. Does anyone know if the master cylinders can be swapped? I dont see any reason they shouldnt.
