C130MARINE
- Aug 21, 2007
- 0
- ft worth Texas
- 1991 Ranger STX
Hey has anyone moved thier coil buckets? any advice.....
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Do you want to move them up or out?Hey has anyone moved thier coil buckets? any advice.....
he is talking about moving them farther from the frame if you are doing a SAS with a full width axleI am going to move them down and loose the 1" spacer on the bottom when i cut off the stock shock mounts and use a shock mount brackets for an f250. What does moving them outward do for me?
That's an awful lot of work when it would be easier to purchase a longer spring....I am going to move them down and loose the 1" spacer on the bottom when i cut off the stock shock mounts and use a shock mount brackets for an f250. What does moving them outward do for me?
Longer springs will lend themselves to more suspension movement, thus requiring the longer shocks and f-250 towers.
