CaverDave
- Aug 27, 2009
- 0
- Ozarkistan
- ford
I'm working on an 87 Bronco II. It is gutless on hills and has a bad idle, loping,way high idle and no idle at random. First thing I notice is in bulb check there was no "check engine" light. I hooked up the scanner and ran tests and pulled codes. Got code 95(fuel pump secondary) Went to test pin 8 for ground and there is no wire on pin 8 and obviously never has been. Then went to replace bulb in check engine light and there is no hole for a bulb or wires in the harness for one. The wiring diagram I have shows a brown wire on pin 8 and a check engine light in the dash. Has anyone else run into something like this? How would you pull codes without a scanner if there is no M.I.L..
I've seen where the DTC 95 can be related to idle problems but with no wire in the harness for that pin it looks like you would always get DTC 95.
As for the gutless I'm thinking the cat is stopped up but the wiring and idle problem has me confused.
David
David
