Cortcase
- Feb 25, 2020
- 2
- Nashville
- Ranger XLT
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- Stock
Ive got a 94 4.0, new to me, 137k miles. It had a bit of a rough idle and slight hesitation when cold. I knew the spark plugs and leads were probably original, so I figured that was the best place to start.
I purchased new plugs and leads from Napa. Gapped plugs, changed one at a time, comparing lead length as I went. Everything by the book.
But after I changed everything, the idle and hesitation got worse. The engine is now clearly misfiring. The misfire is the worst when the engine is cold and it's raining. When the weather clears up, and the engine is warm, you almost wouldn't know there was an issue.
My first suspension was the leads. Perhaps they aren't getting a good connection, or maybe one is faulty. I ohmed them all out, and they were all good. The old leads also tested good, but barely within spec. My second suspension is the coil. This is where we get to my first question.
I tested the primary and secondary, comparing values against Chilton's manual. Spec for the three primaries is .3 to 1 ohm. All three tested .6. spec for the secondaries is 6.5k-11.5k ohms. This is where things get odd. All three coils tested at 14.13k ohms, ±.02, post to post.
This is the first oddity. If two pairs of posts had been between spec I'd definitely reace the coil pack, but since all three are out and even, I'm suspicious of Chilton's spec.
Also, Chilton's testing procedure produced no reading. The manual says to test from pin to post. But the connector pins are part of the primary, therefore they have no connection to the secondary, therefore no continuity. Testing post to post produces a reading, but it's out of spec. But all three are identical.
I'm at a loss. Am I doing something wrong? Should is replace the ignition coil? What are the odds I got a bad plug or two? Is there something else I should be looking at?
