maf sensor
Red_Rider_00
I recently installed a radiator from a 5.0 lincoln navigator into my '01 ranger and I'm wondering if maybe I can also use the MAF sensor off the 5.0 on my 3.0 to increase air flow?
almostclueless
Unlikely....from what I've read, there is a characteristic curve of air flow vs. signal out for each model of MAF, and that MAF is for a different engine. Could the computer be calibrated for it? possibly. Is it worth it? hard to say.
Wicked_Sludge
43
Westport, WA
3-point-GO
MAF sensors are matched to the injectors they are used with. being that the lincoln uses larger injectors than your 3.0, your engine would not run right with that MAF.
you can have either your PCM or the MAF calibrated to make the combo work...but gains will be minimal. i would focus on the puny 50mm TB first.
Viva*the*Ranger
43
Bellingham, Wa.
How much do those 50mm TB's run these days?
Wicked_Sludge
43
Westport, WA
3-point-GO
the stock TB is 50mm...and its tiny.
i belive BBK makes a 56mm TB for the 3.0. an escape 3.0 60mm TB can also be made to fit with a little adapting.
Viva*the*Ranger
43
Bellingham, Wa.
Good deal, I'll have to check that out. Thanks sludge. If and when I do change to the 56mm would it creat any hickups or require any other mod's?
Wicked_Sludge
43
Westport, WA
3-point-GO
no, its bolt on and go.
