MAF help
59sled
california
ford ranger
I recently bought a 1999 ford ranger with a 4.0. After only owning it for about 5 days the check engine light came on. P0174-lean on bank 2. Truck runs fine with code on. So i figured i would start with the MAF sensor seeing thats the easiest to replace. And yes I’m pretty sure this has nothing to do with the code since only one side is coming up. Figured it wouldn’t hurt to replace it.
Bought a Delphi MAF.
I installed it on the truck and now it won't rev. It will idle fine but when I step on the gas it wants to cough/cutout and die. Release the gas pedal and it goes back to idling fine.
I put the old MAF back in and the truck runs fine. Tried new one again to make sure it wasn't installed wrong and still has same issue. So I went back to the old MAF so he can at least drive it.
Anyone have any ideas? Did I get a faulty MAF?
8,370
Yes, you got a faulty MAF
Lean code is not about engine running Lean, it means the computer is adding more fuel than it originally calculated on Drivers side of engine to keep drivers side O2 sensor in correct range.
Could be air leak on lower intake, drivers side
Exhaust manifold leak, drivers side
Dirty fuel injector, drivers side
Older O2 sensor, drivers side
59sled
california
ford ranger
Thank you.
I will try and send this one back and get a new one.
Might have to just drop the truck off at a shop for them to test.
Is this something a mechanic can pin point with a scanner to see if its the fuel injectors or the intake gasket?
Or is it more trial and error?
projectRanger93
313
Los Angeles, CA
Ranger STX
235/75-R15
The easiest thing to do is just buy another Ranger. Problem solved.
8,370
