M5R2 Clutch kit help
FNG
Law Enforcement
Florida
Hey everyone. My local advanced auto parts store has been very kind and patient with me throughout my search for the perfect clutch combo. Having not found proper clutch information, I just dove head first to see what I could make work.
So far, my attempts have been unsuccessful.
I’d come across a forum that stated:
-99-03 F150 M5R2 from a 4.2 V6
-94-96 F150 302 164T 50oz balance flywheel
-94-96 F150 302 clutch disc and pressure plate
When I purchased this combo, (flywheel/clutch plate) the splines on the clutch disc were too small for the input shaft in my M5R2.
Trans is from a 98 F150 4.2.
Does anyone know exactly where to purchase the working clutch combination? The only brand I’ve gone with is the Luk brand from Advanced. Not for lack of funds, but more for convenience.
Thank you!
Roert42
4,988
Kintersville, PA
Ranger XLT
4.0 SOHC
As far as I know the clutch and flywheel should physically swap between the 4.9 and 5.0, I don’t know about the 4.2. Besides the balance weight in the flywheel.
I honestly thought the 4.2 used a T-5 like the 3.8.
I have a full set of if 4.9 clutch, flywheel, pressure plate on the shelf. If you want me to take a measurement of something, let me know.
  • Like
Reactions: FNG
FNG
Law Enforcement
Florida
Thank you, Roert!
I know this transmission to be a F75A (R2). I will send you a DM.
FNG
Law Enforcement
Florida
I have figured out that my input shaft diameter is 1-1/8”. The clutch kits for the F150 5.0 are all coming back as 1-1/16”.
Roert42
4,988
Kintersville, PA
Ranger XLT
4.0 SOHC
Putting my drawing here. Measures 1 1/16" valley to valley. From a 4.9 clutch, should be the same as a 5.0
67273
FNG
Law Enforcement
Florida
Drawings always make this easier. I am going to pick up a caliper micro. and measure mine out.
Thank you, again. I’ll let you know what I find.
Roert42
4,988
Kintersville, PA
Ranger XLT
4.0 SOHC
I'm assuming its a 5.0 you are putting in the truck. What did the engine come out of?
I'm not expert but that may have an effect.
FNG
Law Enforcement
Florida
All good! My input shaft reads exactly the same as your illustration, which is the first time in about a week that I’ve not felt anxious about it.
The engine is out of a 97 Mercury Mountaineer.
I’ve got a flywheel that meets the standards, but clutch combos have been either too small to mount to the flywheel… but spline to the trans, or too small diameter to spline into the trans, but the right diameter to fit the flywheel.
This anomaly had me investigating a slew of different combinations, thinking that I’d perhaps had one or both wrong in every scenario.
So far, the trans checks out to be the R2, and I yanked the engine out of the Mountie myself. So, I know those 2 variables are constant. I’m just confused as to why the combination I’d listed (94-96 F150 5.0) worked for others, but not for me.
Roert42
4,988
Kintersville, PA
Ranger XLT
4.0 SOHC
Honestly I am not familiar enough with the differences in these engines and transmissions.
Here is an old thread on Pirate4x4, https://www.pirate4x4.com/threads/4-2-bellhousing.369596/ , nothing conclusive but some guess work on what would be necessary to convert 4.2 trans to 5.0 engine.
I have a T-5 from a 3.8 on a pallet in my shop, I can take some measurements of the bolt locations on the flywheel. Should be the same as a 4.2. Don't think that would help much.
FNG
Law Enforcement
Florida
You’re the man, and I really appreciate you taking the time to help me with this.
Roert42
4,988
Kintersville, PA
Ranger XLT
4.0 SOHC
The boot holes for bolting the flywheel to the pressure plate are about 12 1/4” / 12 5/16” center to center.
67372
Roert42
4,988
Kintersville, PA
Ranger XLT
4.0 SOHC
The holes for bolting the fly wheel to the crank shaft are about 3”
67374
center to center.
Roert42
4,988
Kintersville, PA
Ranger XLT
4.0 SOHC
That fly wheel is for a 3.8 with a t-5.
FNG
Law Enforcement
Florida
Wow, I appreciate the measurements!
honestly, every flywheel I’ve tried bolts right up to the engine. The issue is the pressure plate lining up to the flywheel, and the correct spline diameter. Seems like the ones big enough to bolt to the flywheel, have a smaller clutch plate diameter (to input shaft) and vice versa.
I found a youtuber who has the R2 swap, but didn’t post much on the details of how he setup the trans. I’ve messaged him, and we’ll see what he says!
Roert42
4,988
Kintersville, PA
Ranger XLT
4.0 SOHC
Btw the id on the spline of the clutch is the same and the other one.
