Lynx_Gen
- Feb 27, 2011
- 0
- Bonnyville, AB, Canada
- Ford
- Engine Size
- 2.3
Well all, time to start a build thread I suppose.
mostly its more of a log for me to go back and referance what I did when and what parts from where etc. A mod/service/maintenace history.
So anywhays, the start.
I've had 2 Merkur XR4Tis. (Technically still got em, although the one is stripped and gutted, more or less, and the other parked.)
As it is, i have a 2.3 turbo engine sittin on the engine stand in my garage.
I had always intended to slap it into my s12, (nissan 200sx/gazzelle/s12 etc) but it jsut needs too much parts and fabricating to get done.
As a result, i chanced across the listing for this 95 ranger, 350$ i was like hmm...
no pic, emailed the owner back n forth. yadda yadda, n up i went n scored it, but due to weather, it was a second 4.5hr trip to get it home.
It passed the test anyways, no rust on the cab, and it had already had a 2.3 and manual tranny.
Puuurfect!
So heres my 325$ truck, that needs a lock cylinder (Picked one up new for 40$ yesterday) and likely needs a clutch slave. also in town and in stock, for like 70-89$ with pilot bearing.
Has some semi fancy rims on her: (I've sinc seen em on other rangers/broncos etc since joining TRS )
And now here is yet another legendary (Lmao) 2.3T lima engine, outta an 85 merkur xr4ti:
A lil upgrade i picked up back int he day.. im pretty sure its hooped tho, but may be restorable.. not certain yet.. need to get it to someone who knows more than me.. (It had sucked in some sand or gravel or some such.. a bit of chipped edges on some of the blades etc...) *Crosses fingers*
its the good one, the 12cm3 as well, not the 9cm3 one.. i had all the specs etc researched and saved aroudn here someplace.. now i cnat even member the proper name for it..
Holset hy35y or hx35y or jsut plain hy35??? something like that..
anyways, its a holset off a cummings.. the welding truck it was on went with a TT kit. lol i worked with his wife, and tinker on his truck a bit from time to time, so he gave me the turbo and exhaust mani and all the intake plumbing etc..
now wether i use this turbo or the OEM one, i do plan to go Twncharged.
Now lets clarrify two things right here and now before any of the typical confusion begins..
Twincharged = A turbo, and A Supercharger. NOT two turbos (TT)
its typicaly used because when setup properly, one will mitigate the failings of the others.. Turbo lag for the turbo, lesser boost numbers for the charger..
Compound Boosting= One Unit feeds into the next (Either directly or through a cooler or whatever.) it pre builds the pressure, and thus the second unit compresses it again (Basicaly seeing the already compressed air as atmospheric pressure) its not exactly double, or half or anythign like that.. its a COMPOUNDED ratio. the downfall is, the inefficiencies are also compounded.
anyways the gist of the plan is simple
im gona fix it up to be driveable, essentialy replaces ignition switch and see why the clutch is takin on air. (Prolly need the slave tho)
drive it around for abit, see hwo the milage is, what kinda power it does or doesnt have etc.
Then swap the turbo motor in as a stock unit, drive it around for a bit again.
Install Megasquirt.
yes, i will be going with the squirt lol.
I have also found the purfect charger for the perfect price, jsut hope its still for sale when i go to buy it and I dont have to settle for an older m90. (this is one the newer more effecient ones, that can spin up to around 16000rpnm versus the 12000 rpm of the older m90s.. (I think i got those numbers right...)
this is the heart and core of this project.
It should be about another week, maybe two, till i get my income tax back, $5300+ so i can splurge and spend a few hundred on MS and a few more hundred on a supercharger... so long as i get my schooling paid for again which is only around 1200.. haha
beyond that, ya the usualy plans. tweak and tinker,
drop it down a few inches, put in a cage, found a nice body kit, but i wana se if i can use it with the pre-runner style fiberglass fenders for lightness, adn for more room for wider tires.. (kind of a widebody kit i guess??)
if i can ever find evidence that you can mate a T56 to a 2.3 reliably, (its been done, jsut doesnt last long because of the adapter bushing or some such from what i've read,) but if i had a t56, i would be tempted to go with somethign as low as 4.59 or whatever gears it was listed, in an 8.8 inch rear end. (I think it was an explorer with disc brakes, as thats one of the big things i wanted..
and either a multilink, or plain old ladder bar setup with coil overs.
found some custom led lights frntt n rear,
n well mostly got everything figured out and researched in my head..
from here on out its all time and money.
but for now, what is certain, and simple and quick, is gona be the engine stuffs..
soo..
anyways, let it begin!
~L~
Puuurfect!
Install Megasquirt.
soo..
~L~
