luis...the Ranger!!
That.1.guy
oregon
2.3
just got a 85 ranger yesterday for $200!! every thing is all original and in very great shape for its age. no ripped seats, cassette radio and all. just needs a new trans. and transfer case rebuilt. its a dual tank, 2.8, fm145 / 1350, not sure how longs its been sitting but tags expired in 98... Motor turns over by had still, can't attempt starting it because bell housing is missing. planning on running 35's. maybe a flat bed.
[/ATTACH]
planeflyer21
19
Sonoran Desert
Score!
That's a great price for a truck these days.
That.1.guy
oregon
2.3
I will post some more pictures if a few but looking at it more it really might only need a tranny. no rust under body and transfer case still has oil residue in it. still has original warranty paperwork in the glove box.
That.1.guy
oregon
2.3
non ruster floor pan
original interior
complete front end with very clean 2.8
RayInStl
14
St. Louis, MO
2.3L
Well, that didn't work. Let's try something else!
Nice! You going to rebuild the transmission and transfer case yourself, or get one from the junk yard? Either way, that was a great price for a solid looking truck!
That.1.guy
oregon
2.3
I was going to just rebuild it but only half on the tranny came with the truck. so for now looking for a replacement. closest in junk yard is 300+ miles away. also no bell housing so cant really try to start it. the other choise is I have a 83 with the 2.3 that just needs a new carb. (works but worn out and no choke) but its 2wd. that truck came with a second long block that just needs rebuilt.
the 85 is in a lot better shape so using it for parts now. so far have all the lights working. need to swap blower motor. 83 has brand new one.
That.1.guy
oregon
2.3
got some time to look at the trans... input bearing is.. well missing... seems common on these. nothing else I'm moving inside tranny. transfer case sifts nice tho .and there was a shinny nugget....
That.1.guy
oregon
2.3
Trying to get a m5od Out of a 92 with4.0
That.1.guy
oregon
2.3
got the tranny today!! gonna clean it at work tomorrow. looks like it will need an input bearing and shifter rebuild? sloppy shifter and leaks oil out the top.
do I need to use the 92 slave cylinder if I keep the stock clutch?
That.1.guy
oregon
2.3
got the transmission mostly installed. enough to be able to start it. so put a couple gallons in the tank and nothing...... so easy stuff first. poured fuel down the carb and it tried to start! so I filled the float bowl and it actually runs! but then it dies. so might need a pump. but to be sure a tried putting a little more fuel in to make sure there was enough and......... the damn thing has a hole in the front tank........grrr
That.1.guy
oregon
2.3
finally got some time to work on the trucks changed plans a little ans am going to use the 83 and swap over the good parts. so already got the interior swappwd and working on getting the front clip swaped ( someone hit a deer before I got it.) how long do you think the stock ttb will last with light crawling and 33s. also with some desert/ sand use
