Locating the Serpentine belt tensioner
seflranger
I need to replace the altenator but need to release the tension on the belt. My manual says to .... "loosen the belt, attach a 3/8 inch drive ratchet and rotate it against the spring force in the direction shown...."
My question is... I can not find where to put the 3/8 ratchet. The Tensioner pulley has a bolt... is it next to it?
Thank you.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
There should be a small square hole on the tensioner arm. This pic probably isn't a Ford 3.0, but it should give you an idea of where to look for the hole.
Earl43P
38
Farmington, Pa
Ford F250 4WD
You didn't list which engine, but you "likely" need to use a 15mm wrench on the tensioner's pulley bolt, to loosen the tension.
almostclueless
Yep.
Robin Hood
3.0L V6
this is the 3.0L forum.
