just a couple more inches
nathan ollila
oregon
my truck is pretty much stock except for the 3inch body lift and 31's..im wanting to lift it 4 inches..suspension..could i get away with just buying the front set up and using 2 inch blocks and exporer leafs in the back?
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Explorer leaf springs plus 3 ranger leaves per side plus belltech shackles on Ballistic Fabrication leaf spring perches netted me over 4 inches of lift WITHOUT the factory block and they flex amazing. I'm running around 3-3.5" suspension lift in the front w/ a 3" body lift.
This isn't even close to maxing the travel out
nathan ollila
oregon
nice..thanks for the info!what did u use for the front?what size tire you running?
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Running a bastard lift which includes Ballistic fabrication rebuildable flex joints on the extended radius arms, custom brackets for the abovementioned joints, Early Bronco coil springs, custom spring buckets, F250 shock towers with 14" travel Rancho 9000XL shocks, heim joint sway bar, skyjacker drop brackets, stonecrusher steering with 1 ton T.R.Es, etc.
Tires are 35" BFG KM2's
