Junkyard swap with the same issue
Richard1316
Texas
2011 RANGER XL 2.3 2WD AUTOMATIC
So I had problem with my truck getting stuck in low gears with overdrive flashing (2nd gear I believe was most frequent, it would not shift up to 3rd but in the earlier stages if I let off the gas it would shift up to third), I could not get my truck into reverse most of the time but on occasion it would fall into reverse and kind of bog out but atleast I could back up a bit, lastly a heard grinding noise coming from what appeared to be my transmission, so I went ahead and grabbed a junker transmission and swapped it out.
On installing the new transmission, I found that I ended up having very similar issues after firing it up. Slipping gear trouble and a hard time switching from 2nd to 3rd gear... And of course no reverse. Overdrive again flashing. Strange thing is, if i shut the truck off and start it back up it goes back to normal for a few minutes until it ends up going haywire again. But hey! Atleast the grinding noise isn't there (for now atleast)
Part of me wants to believe this is something electrical, but I'm also dont trust junkyard parts.
On the new junkyard tranny I pulled 3 codes:
P0733 (gear 3 incorrect ratio)
P0734 (gear 4 incorrect ratio)
P0735 (gear 5 incorrect ratio)
I've heard everything from replace the servos to solenoid pack...
I'm not a professional mechanic, just an HVAC guy who wants to learn a little bit.
Where and what should I start with?
Any help would be much appreciated!
3,614
Yup, sounds like the transmission was built wrong.
Does it have a torque converter, a range sensor, and/or a PRNDL display?
Richard1316
Texas
Yes it has a torque converter and a range sensor. Not sure what you mean by PRNDL display though
sheep herder
1,024
sheep pen
If it ain't broke, break it.
19Walt93
4,498
Canaan,NH
351
3"
235/55R16
Did you erase the memory after installing the trans? It's easy to do and free, unhook the battery for a few minutes, reconnect and run through a drive cycle.Then check for DTC's again.
Richard1316
Texas
Oh okay yes it does have a PRNDL and yes the battery was disconnected the whole time the transmission was out because you have to remove the starter to get to the torque converter nuts
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Did you use the range sensor from the original transmission?
Richard1316
Texas
No I did not the one I used is the one from the junkyard
franklin2
1,772
Virginia
Bronco II
That piece is a common problem on the larger trucks with the AOD. Problem with the smaller trucks also? That's what tells the computer what gear you have selected.
3,614
Yup, it's an automatic. That's your problem.
