- Sep 24, 2009
- 151
- Walls, MS
- Ford
- Engine Size
- 4.0 v6
Let me see if i can list out the issues for you...
check engine light stays on, OD doesn't work, my innova obd reader says codes codes 113: intake air charge temp sensor above max voltage, 117: engine coolant temp sensor below min voltage, 118: engine coolant temp sensor above max voltage, and 123: throttle position sensor above max voltage.
i swapped the air charge temp sensor out with my explorer today, and nothing changed..
btw this is a 92 explorer motor and harness in an 88 b2.
are these related? could it be that all the sensors are on the same harness and it be a harness issue? is the OD problem related?
