- Oct 5, 2007
- Reaction score
- 2,995
- Location
- Toledo Ohio
- Make / Model
- Fords
- Engine Size
- 3.0 2.3
if the cylinder holds compression the valve isn't bent. testing for being hung requires working the valve by hand.
a cheap test would be to remove the other 5 plugs and manually turn the engine over via the crank bolt.
may switch to another cylinder for comparison.
how much difference between the stem heights?
you can check the valve out after removing the retainer & spring.
I run the piston up kind of close to top dead center then stuff at least 2 feet of rope in thru the plug hole then finish pushing the piston up.
the rope will keep both valves from dropping, then remove the retainer & spring. slowly drop the piston a small amount and work the valve to
check free movement. rotate it too.
while a 3.0 is on an engine stand, looking in the plug hole you can see the valves. if you're a contortionist it may be possible while the engine is in the truck.
a bore scope easily gets in there.
lash caps are sold to correct stem height issues, hopefully the valve & seat are OK.
caps depend on if enough stem is above the retainers for the cap to seat on.
being a 2000 you should have 7mm stems.
check the cam lobe too.
make sure the cup in the lifter is up against the retaining clip.
the danger of a loose pushrod is it may jump off the rocker or lifter, very bad as things tend to get stuck between parts.
Free Shipping on Orders Over $109 at Summit Racing
