is this normal..
wpginterceptor
Law Enforcement
9
Winnipeg
Its getting colder out.. I noted first thing in morning when its cold, i start the truck let it warm up for a bit then start driving.. the trucks shifts harder than normal.. it shifts around 3000 rpm FROM 1st to 2ND! after driving about 2 mins then it shifts normal again at 2600 rpm! and its fine rest of time til next chilly morning when I start it, start driving and cant def feel it rev higher than normal and give a slight jerk! Ive cleaned the MAF as was told that could cause issues if dirty.. ive checked fluid and its pink and at level... AGAIN it only does it for first short while, then clears up fairly quick..
ericbphoto
Overlander in development
16,741
Wellford, SC
6"
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,575
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Mine has a bit of delayed shifts when cold... but typically like 0 degrees.
don4331
1,354
Calgary, AB
5.3
Winterpeg (where OP is from) was below 0 F last week.
I wouldn't say its abnormal for it to shift a little higher until engine and transmission are properly warmed up.
wpginterceptor
Law Enforcement
9
Winnipeg
I had an 02 ranger before this one with MANY MANY miles on it and dont recall it doin that, but its been a few years now since I drove THAT.. this new one I usually park in winter and drive my wifes car, this is first winter of driving the 06 ranger with low miles! its chilly here and still nowwhere near as cold as it can get.. hope it doesnt get worse. but def noticed the jerkier shift right off the bat
Uncle Gump
Token Old Guy
13,575
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Sounds like my 06... bought it with 75k miles... did it from day one.
I typically play nice with it for the first few miles. Fluid warms up... back to normal.
8,374
I would agree it is "normal"
Trans fluid doesn't warm up much in Park or Neutral
And the radiator/trans cooler is still icy cold for 10+ minutes of engine running in cold climates, so trans cooler causes slower warm up of trans fluid
If possible shift into R or D and just sit for 30-60 seconds before driving
Torque converters generate the most heat but at idle "in gear" because they are "slipping", on purpose, and that generates more heat to heat up the fluid faster
Regular ATF is thicker when cold like engine oil
Synthetic ATF is not as thick as regular ATF when cold, so might be a good choice next time you change fluid and filter
And yes you can mix them, so don't need a total flush, just more synthetic that regular might lessen that "normal" cold shifting
wpginterceptor
Law Enforcement
9
Winnipeg
This morning +1C or 34 Farenheit this morning.. Start truck left driveway 1-2 shift was 3100 rpm! I immediatly came to a stop, turned off the OD, truck shifted smooth from take off.... after about 30 seconds of driving I turned OD on and all smooth... i dont know..
8,374
Turning OD off and on does nothing in the transmission itself, OD off just tells computer not to shift from 4th to 5th gear above 50MPH or so
Stopping is what helped in this case, unlocked the torque converter so it could slip and heat up fluid faster :)
wpginterceptor
Law Enforcement
9
Winnipeg
Chilly today, when i leave drivewway today ill start off right away with OD off and see.. but yestuyrday was def over 3000 rpm as i watched it
8,374
Also start engine put trans in gear right away and wait 20-30seconds before driving, its also good to get the engine oil warmed up a bit with a load
wpginterceptor
Law Enforcement
9
Winnipeg
OK, so havent drive truck in couple days and woke up today to coldest day all winter so far..
Started truck and let warm up for bout 2 mins (this time I wanted to try something diff) so i TURNED OFF THE OD and left... she drove fine! turned to OD on once I got a few blocks away and was fine..
So far leaning towards an issue with the OD When cold out and first start drivin ( was fine all summer, once temp hit 34F then slow shifts harder)
Next test I will try what you said ron
Will start let warm for 2 mins then put in Drive, wait 30 seconds and go, and iill leave it i OD................. see what happens with that, but im expecting hard shift 1-2 and 3000ish Rpm
PS: had an issue with my lock cyl this morning now too... ill make another thread about that :(
8,374
Put some graphite powder in door and ignition locks
wpginterceptor
Law Enforcement
9
Winnipeg
UPDATE: ok so yesturday was by far coldest day 0F and truck shifted exactly like it does when its 34F. This morning just as cold, so i decided to turn the OD off and left my driveway.. shifts perfect with OD off for first 2-3 blocks UNLIKE Overdrive on!
is it suppose to have diff shift points than when od is on?? why do some say it only affects after 50 mph? cause mine def shifts diff with it off!
After drivin for a couple blocks and it gets up to 40 mph i turn OD on and it drops 400 rpm.. shifts perfect after that again no rough 1-2nd shift or 2nd-3rd shift!
sgtsandman
Aircraft Fuel Tank Diver
12,789
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The shift points shouldn't change regardless of OD being on or off. I think OD just locks the torque converter at a certain point and unlucks when it drops below that. Transmissions are not my strong point but that is my understanding of OD.
