Junk Collector
Truck of Month
- Mar 4, 2008
- Reaction score
- 4,850
- Location
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Open diff isn't really that big of a deal... with 200k on yours, the clutches are probably long gone anyway, it may have been operating as an open diff for a long time!
You could also remove the carrier from your axle, buy a new clutch pack and have it set up in your junkyard housing.
Kinda curious what actually happened to yours though - I think you should pull the carrier and inspect everything. Could be that a spider gear broke. If the ring & pinion are in good shape and the bearings don't look awful, I'd be tempted to clean it out really well, replace the spiders and run it.
This is what happens when C clips fail or are not present by the way
