2.5L ('98-'01) Intermittent throttle. Can't drive it....Issue now rectified.
Dirtman
9,895
41N 75W
It's up there.
It's down there.
Round.
Glad you fixed it but just to clarify something here, throttle body/intake cleaner is NOT the same as MAF cleaner and should not be used as a substitute.
Rock Auto 5% Discount Code: 7FA902352B4C01: April 5th, 2021
DCman
12
Poulsbo, Washington
Ford Ranger XL
2.5 (4 Cylinder)
P205/75-R14
That's not what the guy at NAPA said, but I'll capitulate to your knowledge.
What's the difference between the two?
Dirtman
9,895
41N 75W
It's up there.
It's down there.
Round.
MAF cleaner is extremely mild and designed with one purpose, to not leave any residue of any kind whatsoever behind. Any trace of chemical residue left on the heated MAF wire can cause it to burn up.
Throttle body cleaner is much harsher and designed to simply clean crud. It's not as harsh as old fashion carb cleaner since it needs to be safe for plastic and teflon coatings but its still too harsh for a MAF sensor and will leave residue behind.
DCman
12
Poulsbo, Washington
Ford Ranger XL
2.5 (4 Cylinder)
P205/75-R14
hmmm, my can of TBI cleaner acts and smells just like carb cleaner.
Learned something new, I guess.
I'll remember that next time. Thanks.
franklin2
406
Virginia
Another comment on messing with these engine systems. The computer has the ability to "learn" and compensate for some sensors being off a little bit. It may have been way out with the old MAF sensor. And then you put the new one in and it's slowly figuring out what happened and trying to compenate for that change. So you may find it takes a couple of drive cycles and it runs better and better each time.
