Intermittent starting
Mwlock
Manitoba
Ford Raher
95 Ranger. 4.o liter. 6 cyl. Auto. 4x4. Starts sometimes. Tried the common issues. Ground. Power. Fuel pump. Inertia switch.
Any other thoughts?
8,370
"Starting"covers some ground
Does starter motor not turn engine over?
"No crank"
Does starter work but engine won't fire/start up?
"Crank but no start"
Once started has it ever quit running?
Does it only not "start" warm?
Or does it not "start" cold as well?
Mwlock
Manitoba
Ford Raher
"No crank"
I can crank the engine and get no spark. Just drain the battery with too many attempts. Not affected by weather/temp that I can tell. It has run for two days without issue then won't start the next day.
Thought it was fuel pump but that cycles just fine.
Replaced fuel filter.
Did not consider starter issue. Would it crank but not start in ground was loose or off the starter?
8,370
No, if starter motor is working that wouldn't effect engine systems
You will need to do the 50/50 test, best thing to do so you aren't guessing spark or fuel and replacing parts that are OK
Get a can of Quick Start(ether) and carry it in the truck
Also a pair of pliers and screwdriver
When you have a crank but no start, pull off the larger vacuum hose from the Power Brake booster usually just a hose clamp
Spray fuel(ether) into the hose and you can leave hose off for the test
Crank engine
If it starts and then dies your have a fuel delivery issue
If it doesn't start then you have a spark issue
50/50 instant results
Fuel delivery can be fuel pump or computer(not opening injectors)
No Spark can be Crank sensor or computer
Also when cranking engine over WATCH the CEL(check engine light), it should come on with key on, that means computer has booted up, if no CEL then computer is OFF
When engine is cranking(turning) CEL should go off, that means computer is seeing the engine turning and will start spark and then injectors
Mwlock
Manitoba
Ford Raher
Thanks!
I will give it a shot.
