MJ'sBlkBII
- Aug 3, 2008
- 1
- Harker Heights, TX
- Engine Size
- 2.9 V6
I have been having a very high idle (between 1200-1800 rpm), a lot of smoke/steam and condensation from tail pipe with a very bad smell (think sulpher as a posed to fuel, but wife says it smells rich), rough running when cold and smooth[er] running when warm. I have been going over everythng I can trying to figure it out. I have replaced the coolant temp sensor (2 wire), air/fuel mixture sensor (was nasty black), IAC (also nasty, wouldn't clean), and O2 sensor. I pulled codes and got TPS low voltage and O2 always lean. I tested the TPS and seems to be in spec. I have it adjusted down to .8 at the moment and it is at 1200 rpm, at .91 it sits about 1800 rpm. At WOT it is just under 5. I don't hear a vacuum leak and have checked lines and connections. The only line I don't seem to have any vacuum is the lines to/from the canister next to the radiator. These lines can be disconnected with out any change to rpm's. All others do make a difference. I pulled the plugs on the TPS and IAC and there is a slight drop in rpm. I pretty well soaked the motor in carb/choke cleaner but had no variation in rpm. I got curious (read frustrated) and placed my hand over the throttle body and got very good suction, the engine rpm's dropped and the engine stumbled then I got a very loud whistle seeming to come from the right rear of the intakes (as looking from the front end). This is what I was looking to get, but is this a possable way to identify a vacuum leak? I figure the engine would stall unless it could get air from a leak.
Let me what ideas y'all might have. Thanks.
