2.5L ('98-'01) Intake Air Temperature reading hot
Alam0
5
Houston
The outside temperature is 74deg Fahrenheit, but on my OBD2 scanner it reads the Intake air temperature as 134deg Fahrenheit.
I'm just wondering if this is bad for the engine? My idle is around 1000rmps fully warmed and I get this foul smell from the exhaust.
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
Is you sensor good?
Alam0
5
Houston
Is you sensor good?
It looks to me like its bad. My other ranger's IAT reads 84deg Fahrenheit I'm also having a hard time locating it. Is it built into the MAF sensor?
scotts90ranger
4,374
Dayton Oregon
2.3 Turbo
possibly, other times it's a 2 wire sensor in the intake tube or air box. Honestly I don't remember where it would be based on my '97...
This doesn't by chance have an aftermarket "cold air intake" does it? if so, that would explain a lot since that puts the intake just over the exhaust manifold... 150F stopped at idle isn't unheard of, underhood temps can get high and the intake velocity is very low at idle so it has time to warm up.
Alam0
5
Houston
No aftermarket cold air intake. Just the factory air box.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Where is the sensor?
That can be normal at idle. What is it at cold start?
It is a relative....just depends on where it is.
It should go down to within a few degrees of ambient once your moving.
Not sure what engine you have.....or what method the tools you are using are implementing to scale temp.
scotts90ranger
4,374
Dayton Oregon
2.3 Turbo
Bobby, it's in the 4 cylinder section labeled as a 2.5L so that should help...
The alternator went out again in my '97 so while I was there I snapped a pic of the air temp sensor in the air tube... the two wire sensor just ahead of the throttle body.
