gman-1970
- Nov 15, 2011
- 0
- Ford
Hi all,
First, thanks in advance for any replies. Hoping someone has some good news for me, as I REALLY don't want to pull this engine right now....
So, I have a 94 Ranger XLT SuperCab 4WD, 5-speed. I have a coolant leak (external) on driver side head gasket. So, since I have to pull one head, I decided I might as well pull them both and have them tested, replace the gaskets, MAYBE a valve job, guides, seals, etc. This engine has over 200K miles, (mostly highway) and runs great - doesn't use a drop of oil and vacuum is perfect. I plan to do a compression test and leak down test before I get too far into this just to be sure. Don't want to put a bunch of time / money into it if it's got a bad cylinder or what not.
ANYWAY, I was reading my "handy" Chiltons on replacing the camshaft and it has a couple things that concern me:
- "Remove clamp, bolt, and oil pump drive from the rear of the block"
? Assuming this is on the top of the block, and not on the backside?
Now the SCARY stuff:
- "Remove the oil pan as previously described"
? Ah, Why? To get the front cover off? And if so, can it just be dropped a bit vs totally removed?
- "To remove the oil pan, remove the complete engine assembly from the vehicle"
? WTF? IF this is necessary, a cam swap is non-starter for me - too many other projects to invest this much time right now. If I have to pull the engine, I would either do a 5.0 swap or at least rebuild the 4.0, as regardless how great it seems, 200K is too much to reinstall. And since the syncros are bad in the 5-speed, then I'd fix that as well. Just too much work right now... If it can be done without TOO much more work than pulling the heads, then I would like to do it along with some other BPU's, as this 4.0 is ANEMIC IMHO, especially for the crappy MPG. I'm fine with what I consider poor performance if the MPG is good, but I don't think I even get 17 on the highway - MAYBE.
So, any advice / guidance would be GREATLY appreciated. I'm hoping someone has good news for me, and I don't have to pull the engine. I'm fine with everything else, including AC condenser, as I'm replacing a bunch of AC stuff anyway.
OH - re the 49-410-8, anyone used this can tell me what length pushrod I have to use? Apparently the stock ones won't work, but not sure of they are too short or too long or what. What a PITA. If they are a BIT too long, what about shimming the rockers a bit to compensate? Or would that jack up the geometry?
Thanks again!!!!
Gary
Thanks again!!!!
Gary
