- Mar 9, 2012
- 4
- Ohio
- Ford
- Engine Size
- 3.0
Back to ignition problems for me... yeah I've got a mess on my hands that all got to get cleaned up. The guys that have been here for a while probably remember when I messed up the truck last year, now I'm finally fixing it.
Had the broken clutch pushrod, fixed. Now the starter interlock works... No fuel pump, fixed. Needed a relay, the old one popped but wasn't a strong enough connection I guess. Easy fix. When I got it back the spark plugs weren't gapped right, and the plug wires were mixed up, easy fix.
Now here's the more complex problem: cranks, but no fire. Has fuel at the rail, has fuel come out the exhaust. So I'll assume the injectors work. The plug wires were new a year ago. They have all of 20 miles on them. Plugs are questionable but I inspected them and gapped to .054.
I have 12v to the hot wire at the coil pack with KOEO, and 0v at the 3 ground wires (as it should be). I pulled the wire off the coil for the middle drive plug (front/left on the coil) and held it close to the coil. It gave a spark then fired that cylinder. But it won't fire that cylinder with it plugged in... I'm lost.
Thinking that I need to get the coil pack tested as well as the ICM. I had replaced the PCM already.
