idea for extended cab sub box
Blacked-Out FX4
Dirty Jersey
:icon_idea:this is my plan for using my extended cab seeing as tho the jump seats are hardly worth using...what do you guys think?:dntknw:
ranger92
Kelowna, BC
3.0l
looks sweet i like it alot. Now lets see the real deal! :p
rj_conerly
abita springs, louisiana
2.9 liter
i agree i wanna see it, but i got some things for you to think bout for it first.
do you have the right air space and if you port it and set the ports up to go in the middle and put some neons or leds shining out of the holes on to the amp that would look hot as can be.
also make sure the amp can get enough ventiation to the amp to make sure it doesnt over heat from the sun possibly shining in on it.
just some things to think bout before you build the box
crazywhiteboy
May 2011 OTOTM Winner
clearlake, ca
the amp will not overheat from the sun shining on it..and you dont need a wind tunnel for adequate ventilation. i have my 4channel in the pocket where the jump seats used to be and im pulling everything it has to offer and it has yet to overheat. yes, it gets so hot that you can barely touch it at times, but it hasnt ever gone into protect or shutoff on me.
kawasakikid
looks pretty good! i sat on a bunch of sub box ideas before i finally came up with a legit one. i built a ported box for my 12mtx 7500 that fit into the hole that was previously occupied by the jumpseat on the driver side. that way i could still use one of the jumpseats and have a little room in the back. and the one 12 is just as punchy as dual tens. i could send you a pic or even specs if interested.
kfx400guy
Omaha, NE
I'm planning on doing something just like you did. What was the cubic footage of the box? Could you possibly send me some pics or even specs if its not too much trouble?
tylork92
im making a falsefloor to level out the back since that dang hunmp is back there....under it will be were a few fans and my amps will be mounted. sub box will span the entire length so i can keep it unde winsow line....subs will be forward port will be up.
crazywhiteboy
clearlake, ca
who are you talking to?
crazywhiteboy
clearlake, ca
yeah you pretty much have to make a false floor..otherwise its a huge obstacle to work around
