how to power home compressor
fordbrian333
e. yaphank
how big of a power inverter will i need to power a 1ph dual piston compressor?
kunar
131
Toledo, Ohio
5.8l
look at the info plate on the motor and find out how much power it draws.... thats your answer.
kimcrwbr1
46
maplevalley WA
2.8l
I`m not sure you can produce the amps needed from a 12 volt dc. My compressor motor uses 16/7.5 amps 240/120 volts the inverter needs to push at least the lower number.
kimcrwbr1
46
maplevalley WA
2.8l
7.5 X 120 = 900 watts
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
get a second battery... a really big, expensive, deep cycle one. get a dual battery charger system installed with your alternator. get a 4000 watt/surge, 2000 watt/continuous inverter. give it a shot.
just my $.02.
