How hot should it get?
bigalpha
95 2.3L, stock.
My temp gauge take forever to creep upwards, and barely gets above the bottom of the gauge, yet the truck runs fine and heat blows hot. Where's the needle supposed to be?
Bryan22
4
So-Cal babay
94 extd
94 2.3
the stock guage sucks, mine never gets into the normal range either. as long as you've got heat and it runs right i wouldn't worry about it. you could always install an aftermarket guage for a true reading though.
fastpakr
2,849
Roanoke, VA
Yep. It's not calibrated to a temperature, and it varies from vehicle to vehicle. Get a real gauge.
Mirage
Mazda
2.3L
Mine had the same problem, always appeared to be running cold. Then one day, it started running reading really cold. I replaced the sending unit for like $15, and it now reads normal. But remember these stock temp gauges aren't really calibrated, you would be better off with an aftermarket gauge if you really want to know the exact temp.
bigalpha
Alright, I was just curious.
The temp. gauge in my Jeep is fairly accurate so I wasn't sure if it was in the Ranger. It was throwing me for a loop.
bigalpha
If the Temp gauge sensor is wonky, can that affect anything else on the truck?
Wicked_Sludge
43
Westport, WA
3-point-GO
no. the temp gauge system is all independent.
bigalpha
So really, I don't need to worry about it at all.
Thanks.
Wicked_Sludge
43
Westport, WA
3-point-GO
provided its the gauge thats wonky and not your cooling system...
bigalpha
I assume it is, because I have hot heat, no overheating, and the gauge reads the same consistently.
How much do the temp sensors usually run? Could it be a bad sensor that needs replacing?
Wicked_Sludge
43
Westport, WA
3-point-GO
temp sensors are usually $10 or so. it could be a failing sensor, but more likely its working just fine. as others have said, these gauges are not calibrated, not accurate, and vary from truck to truck.
bigalpha
So I could end up getting a new sensor that still reads low?
Wicked_Sludge
43
Westport, WA
3-point-GO
thats a distinct possibility.
