How do you remove this clip easily?
rubydist
867
Denver
Ford Ranger FX4
I use a small flat screwdriver to bend the little tangs away from the threads on the stud. Then it just slides off easily and goes into the scrap metal pile.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I use the Schwartz.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
It's easier to remove if you insert a small screwdriver under the ears an pry a few of them back. Doing this allows you to reuse the clips. To reuse, just tap the ears back down with a hammer, works every time.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
One other thing. Welcome to the club.
sgtsandman
Aircraft Fuel Tank Diver
12,774
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Those clips are installed during original assembly to hold the rotors and drums in place and make things easier for the assembly line worker.
Keeping them is up to the individual and are not necessary for safe operation.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Same with the screws on rotors. I usually chuck them right in the trash. The wheel holds the rotor on. There is no practical use for the screws after it leaves the assembly line. Especially here in the north where they are almost always so rusted on that they strip out and need to be destroyed to remove. They only exist so the car can be sent down the assembly line without the rotor/drum falling off before the wheels get mounted.
sgtsandman
12,774
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I never had a problem with the screws but I never reinstalled them more than snug. However, you are not wrong either.
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
My father worked at the Edison assembly plant installing right side tires on Rangers. He shut down the line once because the guy who put the drums on wasn’t installing the clips.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Did he get pissed after the 3rd or 4th drum fell off onto his foot?
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
No, but if a drum fell off, he is enough of an A-hole that he would have put the tire on anyway.
Long story longer...
The trucks were coming down the line without the clips. The drums were loose, and sitting crooked. That made it more difficult for him to do his job in the time he had.
Most stations on the line have a little more time than the tire guys. The big lug nut gun (installed and torqued all 5 lug nuts at the same time.) didn’t have tons of side to side movement. If it took too long to seat the wheel, than you could not have enough time to fully torque that wheel before you ran out of side travel.
So he shut the line down and told his supervisor to “make that motherf****er do his job right, so I can do my job right”. His supervisor came back with a handful of those clips, which my father promptly smacked to the ground.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
That would make for the worlds funniest TSB.
Braking issue -
symptoms - lack of stopping power and noise from right rear
Problem - Bob (whatever you're dads name is) got pissed off
Solution - install a drum on the right rear wheel.
pjtoledo
2,998
Toledo Ohio
Fords
3.0 2.3
most factory wheels have a small pocket on the mounting surface around each stud to make room for the clips.
some aftermarket wheels don't, in which case the clips can cause a poorly mounted wheel.
I ditch 'em.
sgtsandman
12,774
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Time is money and workers only given so much time to complete the task. I can see legitimacy to his argument.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
That's why people get replaced by robots on assembly lines. Robot's rarely argue.
ericbphoto
Overlander in development
16,734
Wellford, SC
6"
I beg to differ. My robots argue way too much. Besides, the robots can only do so much. There is a lot of equipment that "assists" the employees to reduce ergonomic injuries. The assembly lines, these days are amazing. There are still a lot of people involved.
