thats intresting that they dont use a gasket on the 2wd extention housing, yet there is indeed one on the 4x4 version between the extention and the transfer case, even though there is a cut out for drainage at the bottom of it.
Do you enjoy making pomegranite/watermelon comparisons?
We are talking about the extansion housing (aka "tailcone")
connection to the main transmission case.
the connection at the OTHER end of the 4x4 extension housing is another discussion, but technically speaking on a 4x4 Mazda trans the paper gasket doesn't actually seal anything.... there is a shaft seal in the back of the Mazda 4x4 trans and atleast theoretically that area between the trans and T-case is supposed to be dry.
However that little seal fails more often than not and THAt seal can dribble every drop of oil out the back through a drain "sipe" passage in the Tailcone-tcase gasket surface.
that can bleed all your oil overboard on a mazda trans without no outward sign that isn't masked by the normal trace leakage from above...
So I recommend using RTV between the trans to T-case surface with particular attention to sealing up that little vent sipe to prevent catastrophic oil lose for WHEN (not "if") that seal fails.
On my OWN trans I drilled and tapped (threaded) a hole in that little sipe groove and epoxied an aluminum screw in place and then using a single cut file cut that surface perfectly flat...
Previously I've had a welder put a blob of Aluminum there and cut it smooth.
But frankly a blob of silicone the size of half a peanut does the job...
AD
