How can I remove gas tank?
cvar
19
Mazda
4.0L V6
OK, I'm stumped. My '97 B4000 is up on (front) jacks, but sitting on its rear wheels (as normal). The bed is off, gas tank skid-plate is off, tank straps are out, all hoses are disconnected. Most I can do is shove the gas tank sideways a bit, but I cannot figure out how to remove it. Awk!
The gas tank's small front end is trapped by that T-case crossmember. I tilted the gas tank's rear end down by about 10 inches, but can't go any further cuz the tank just hits the rear axle & diff. Driveshaft prevents going sideways. So... what's the trick? How to remove it?
I'm gonna replace all 4 hangers, shackles, & leaf springs eventually. But meanwhile I'd like that pesky gas tank outta my way. Surely it's removable w/o dropping the rear axle?
cvar
19
Mazda
4.0L V6
Never mind. Jacking up the rear axle squished the springs, giving just enuff clearance to wiggle the tank out. Why is everything such a tight fit?
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
I'll be honest I don't even try removing the gas tank from a ranger with the driveshaft in the vehicle
snoranger
Professional money waster
ASE Certified Tech
13,731
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
:icon_idea: Because its a small truck.
Ranger Kip
10
Wellsboro, PA
Ford Fleet
3.slow
Confused and Intolerant
get a full tank of gas and ignite the gas tank, should burn it off in a few hours, so just let it sit
MazdaHawaii
The Big Island of Hawaii
Mazda
Do or do not. There is no try.
I had the same problem and removed the rear axle. I think it would have come off without doing that if the prior owner had not put in lift blocks between the top of the axle and leaf springs. I didn't mind. It allowed me to more easily clean up the frame and paint it.
