high beams-yes low beams -no ??
579
I searched the posts a bit and didnt find any thing similar to my problem. MY high beams work but my low beams do not. any ideas?
Original_Ranger84
20
Homer, Ak/ Anchorage, AK/Fairbanks, AK
2.8L, 3.0L
Well your bulbs may be burnt out on just the low beams if you use them more often but it sounds exactly like the problem my friend is having with his 93. We ended up replacing the multi switch with a junk yard one and they worked for a while but now its starting to happen again and I couldn't find anything wrong with the old switch so I would start checking the plugs for bad or corroded connections.
nitrofan1
Man without a Ranger
MTOTM Winner
19
Chattanooga, Tennessee
Subaru
EJ251
Well since you didn't put you rig info in either the sidebar or a signature we'll have to guess. 1. The dimmer switch is bad. 2. The main fuse box under the hood may have a low beam headlight fuse that's blown. 3. Also bad bulbs but those are Vegas odds that they'd both blow the low beam filament at the same time.
The problem is if we don't know what you own & drive we have to generalize our answers.
579
Yep. Sorry. I was distracted. It's almost like yours. 94 2.3 with the a4ld.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
the bulbs are bad. i saw this 1000 times during my autozone days. go get new bulbs and put them in and i bet they'll work
Original_Ranger84
20
2.8L, 3.0L
Not nessiscarly ecause my friends had both lows working after we fiddles with the plugs in the dash column.
Although he could have not noticed one went out because it was so dim to begin with and then only noticed the second one going out....
579
well it was not the headlight itself. I bought a new one. same problem. only brights work. I checked all fuses in the dash and under the hood. as to relays and multi-switches, I have no idea where these items are so I cannot check them. I alos checked the gounds that are responsible for the headlights and they seem tight and in good condition. i wiggles the harness that goes through the firewall in the engine compartment and under the dash to see if I got a flicker or something. nothing changed as I worked. the low beams didnt work nor did they flicker.
IM stumped.
EMB1230
Kenosha, Wi
2.3L
Multi function switch = turn signal/wipers stalk.
579
Charles
1988
ford Bronco II
579, did this cure your problem?
Got the same problem, High beams work, no low beams. Turn signals work, wiper works.
Fuse, relay or something that central to low beams only?
Multi switch..... that's the switch that controls the headlight beams and the wipers correct?
How is it removed?
kimcrwbr1
46
maplevalley WA
2.8l
Chances are pretty good it is the connector to or the turn signal dimmer switch. If the brights work then the power is good up to the dimmer multifunction switch. Highs and lows use the same circuit from the light switch. Correct wiper washer, turn signal and high beam hense the name multifunction.
Navyrs
Arlington, TN
2.3
I had a similiar problem with my 91. I kept blowing my passenger side headlight. I bought a HEAVY-DUTY HEADLIGHT HARNESS from LMC. The part number is 47-3661. It runs the power for the lights thru a relay, instead of thru the switch. I havent had any problems with my lights and they are a lot brighter. Only cost $30.00. Hope this helps.
Charles
1988
ford Bronco II
Thanks everyone!
Charles
1988
ford Bronco II
It was the switch. I could see two problems.
1- The "Brown" connector at one spot had gotten very hot and melted partially.
ditto on the switch in the same spot.
2-The "white" connector had one of the wires pushed out, it doesn't lock into the connector like the others do, so when you push the whole connector onto the switch, a wire in the back has a tendency to push out of the back.
I swapped the switch with one from my Ranger just to see if it would work, and it did.
Not sure what made the "Brown" connector overheat though.... something common?
rosscob
33
Oregon Coast
Ford Ranger XLT
I don't mean to hijack your thread but I'm having the opposite problem on my '88 XLT, headlights work, just no high beams. Turn signals work fine but when I hit the high beams the lights go out, the high beam indicator in the dash doesn't even light up so I don't think it's the bulbs so I'm guessing the switch.
