Help!!!!
Buzzard
Firefighter
ASE Certified Tech
4
Bland County Virginia
4 inch
31x10.50 R15
Okay so long story short I have a 1988 2.9 XLT with manual trans, I’ve replaced the rotor button and cap. I’ve put a new coil on it and a new ICM I have spark coming from my coil but not my distributor and Idk what to do from here, it cranks over but will not fire
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
So you have spark at the distributor from the coil wire... but no spark at the plugs through to plug wire?
ericbphoto
Overlander in development
16,620
Wellford, SC
3.0L
6"
Timing off? Is the distributor actually rotating? Bad wire from coil to cap?
Buzzard
Firefighter
ASE Certified Tech
4
4 inch
31x10.50 R15
Could it be a fusible link and if it is where do I get new ones
Buzzard
Firefighter
ASE Certified Tech
4
4 inch
31x10.50 R15
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
There's no fusible link between the coil and distributor.
8,371
Spray fuel into the intake to confirm No Spark, 50/50 test, humor me :)
So coil sparks in rhythm while cranking engine over, not just one spark, so ICM is timing the coil
And no spark on #1 wire, if so then rotor is bad, its not passing spark, or new cap is, center plugin is bad, no connection to rotor
And that's all it can be, not a complicated system
One thing to check is if the Coil's + terminal has 12volts................while cranking, in 1988 there can be TWO 12volt pathways from ignition switch to Coil and ICM, one for RUN, and one for START
In RUN(on) 12v comes from a red/blue wire, then in START red/blue 12v is cut off and a Brown wire provides the 12volt for startup
This is a hold over from the Ballast resistor(wire) days
Long shot but not a no shot
There is a hall effect sensor in the distributor, it reads the "vanes" as distributor turns
The ICM(TFI) uses the "Vane pulse" to time the coil's grounding
Coils have 12v on + terminal when key is on
The ICM grounds the - terminal to charge up the coil then UNgrounds the coil to get it to Spark
You can test if coil is getting the "ground pulse" by using a 12v test light from battery Positive to Coil -
Test light will pulse when you crank engine
If you have a tachometer you should see it move when cranking, thats the ground pulse from ICM
Also if you have a CEL(check engine light) it should go OFF when cranking, that also means there is a ground pulse from ICM
