Help with Wiring
'36 International
San Leon Texas
I am needing help/ advice on my latest project. I have a 1936 international truck with the engine (3.0) transmission (auto) and rear end out of a 2003 Ranger. The truck is a rat rod with no gauges or speedo at this time and the wiring should be very basic. It ran when purchased but had the factory wiring harness with all the unneeded electric window, locks, dash gauges, PATS etc. wiring. Its open engine hot rod style and I wanted to clean up the harness. Im lost when it comes to wiring and re-programming PCR's. It has been through one (shade tree) mechanic, and another local hot rod builder in the last two years and the rewire job is still not complete. I have tried to get someone local to take on this project but no one will touch it. At this point Im looking for someone to build or reprogram the computer to make the engine run and give me a wiring diagram. Any advice or contacts would be appreciated.
19Walt93
4,491
Canaan,NH
351
3"
235/55R16
If you can find an EVTM for the 03 Ranger it'll be a big help. EVTM is electrical.vacuum troubleshooting manual if you're not a Ford guy. It's a wiring diagram broken down by circuit to make it easier to understand.
Guanfy
91
Crawfordville, Florida
Mazda B3000
Stock
Stock
15in
+1 for this. I have the paper book EVTM for mine and it's exactly for the situation you are in. They can be found on eBay in a cd or paper book format for under 50 dollars if you look around.
