help with timing my 2.9L
broncodave93
FORD
I know how to time a ford with the spout connector.....I just can't figure out the best way to get to the bolt that holds down the distributor. Are you guys using a long extension with a "wobbly" socket at the end? or try to cram your arm down between the motor and firewall and use a wrench??? any help would be nice
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
I used a ratchet with a 13mm socket before my body lift, with the body lift I can reach back there really easily with a wrench.
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
And I'm probably the only one who will say I have the CORRECT
(and L O N G discontinued) SnapOn Distributor wrench.
AD
2manyfords
Brandon Manitoba Canada
I go after it from the drivers side with a short 13mm wrench.
It's a bitch loosening it if it's tight but it can be done.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
I had good luck with a ratchet from right next to the driverside front tire. Honestly, I didn't have much trouble getting to mine at all.
Psychopete
29
FW, IN
I recall having to use a 13mm wrench. I am ~6' and 140lbs, so I can fit my hands and arms around/through things pretty easily. I do remember it being kind of awkward. Just take a varitey of stuff with you (extensions, wrenches, deep/short sockets, etc) and just find something that works for you. Seems that a ratchet w/ swivel head would be a good fit, but I am not looking at the engine right now :). Those always help extensively on top bell housing bolts.
Pete
AllanD
TRS Technical Staff
135
1987... sorta
'93 4.0
BTW, I just gotta ask...
why do you NEED to adjust the timing?
Timing on a 2.9 is only off if something is worn.
AD
broncodave93
FORD
I needed to set the timing cause I just swapped in a used 2.9 in my 89 bronco2 and for some reason the distributor was loose. I managed to get to the bolt by using a socket wrench with a short extension and a short wobbly 13mm. thanks for the ideas guys
AllanD
TRS Technical Staff
135
1987... sorta
'93 4.0
Ahhh.. the other reason, so previous engine plumber messed with it before you arrived...
AD
