eezynee
- Apr 5, 2021
- 0
- Santa Cruz, CA
- Ranger XLT 2.9
Hi, I have an 87 with the 2.9, it took a shit on me a couple months back, just died as I was driving down the road and would crank but not start. I ended up replacing all kinds of parts to try and get it started and the TFI module was what finally did the trick. Throughout the process I've put in a new coil, plugs and wires, a new in tank fuel pump sending unit, new EGR valve, sensor and solenoid, new TPS, new ECT, I think a new MAP too but not sure on that one, replaced the fuel pump and ecc relays, and replaced the computer with one from the junkyard. I used to have way more codes but they've all gone away with the exception of 21 & 77, for the ECT sensor and the TPS, which I've replaced with new parts twice. The truck starts right up every single time and idles smoothly, but has a weird throttle issue where it almost won't let me go past 2000 rpms, and if I floor it it will eventually fight through until it's smooth again at 5000 rpms, but between 2000-5000 rpms it jumps around like crazy, and the exhaust is pretty white. I'm not much of a mechanic but I can usually figure some stuff out if I find an example online of someone experiencing the same issues and they found the solution. It's entirely possible I messed something up while putting in the new fuel pump or any of the other little projects I've done.
Any ideas?
Any ideas?
