help setting up carb....???
kimcrwbr1
46
maplevalley WA
2.8l
If your jets are .65 or larger I would say your safe to drive it. Because your 30 over maybe you can figure the percentage of cubic displacement higher and ad the same percentage to the .65. You can also run a little rich on the idle air screws if your worried. That carb came out of the box plug and play If your vacuum is good work it. I put a carb on my 2.8 that has .46 jets and the book says .48-.50 and she runs just fine but I never red line it. If your not running 5-6 k WOT for extended periods give it a shot.
baddad457
18
Opelousas La.
Mine is thr same way so should I just drive it or what but I don't want to screw my motor up
It takes a lot to screw up an engine. If after you've driven it 50 miles and your plugs still look like new, it'll be fine. My plugs have looked like that for 4 years now. A cold hesitation is normal with a carbed motor. If you got in mine and drove it after it's warmed up, you'd never guess it had a carb, unless I told you. If it starts easy, has a good idle and performs like you want it to once it's warmed up, drive it and enjoy it. That's what you built it for isn't it ? From what I gather from this thread, you've suffering from TMI here. Drive it, tinker with it when you have time and otherwise don't worry about it doing something it's not likely to do. Cross those bridges when you come to em.
ford1386
Gardners, PA
306
If I jump up a couple jet sizes do I need to jet the secondaries the same also. I think I have a 65 in primaries so if I jump to a 68 then do I need to jump up 3 sizes on the secondaries also....
baddad457
18
Opelousas La.
No.
ford1386
Gardners, PA
306
Well I think I'm gonna jet up a few sizes on the primaries, because I worked on my uncles 81 f150 this past weekend. He has a carb 302 in it with an autolite 2 barrel and I pulled 2 spark plugs on it and they were a light toasty brown, so I must be too lean cuz he has color in his plugs and is running the same fuel I am....
1mean02hd
Chase, MD
5.0L V8
Are all your vac ports used and/or plugged?? Have you checked for vacuum leaks? That 670 really shouldn't giving you this much trouble especially right out of the box. Should have been able to drop that puppy on there, set the idles and run it. Like Baddad was saying, once a carbed motor is warmed up, you shouldn't have any issues with it if it is tuned correctly (mine has no choke on the Demon). Also just a tid bit of info, if you go changing jets, you cannot compare a Holley number with the same number of another manufacturer's jet. Normally there's a chart that comes with jet kits.
ford1386
Gardners, PA
306
Yea I bought a holley jet kit, so the numbers are sized the same as the jets in the carb. But the truck is running almost 100% but I'm just trying to figure out why I can't get any color on my plugs when my uncles 81 f150 with a 302 has light toasty brown plugs in it.
baddad457
18
Opelousas La.
If you're happy with the way it performs, leave the jets alone. Different brands of fuel have a lot to do with plug color as well.
ford1386
Gardners, PA
306
kimcrwbr1
46
maplevalley WA
2.8l
I`m just wondering if the plugs your using are making the difference what kind of plugs is your uncle burning in his 302.
ford1386
Gardners, PA
306
I will take a look, but I know I am running a set of autolite platinum plugs and the two I put in to check for color are regular champion plugs
kimcrwbr1
46
maplevalley WA
2.8l
I prefer autolite single platinum and have never had one foul. Most TRS members recommend motorcraft but with your ignition system not being stock maybe the manufacturer has some recomendations on the proper heat range for your engine.
baddad457
18
Opelousas La.
I use the plane jane Autolites and they last forever with a good ignition. The ones in my Ranger are about 4 years old now and still look like new. Platinums are a waste of money. Champions ? You don't want to know my opinion of them.:icon_rofl::thefinger:
kimcrwbr1
46
maplevalley WA
2.8l
+1 on your opinion on champion plugs never had any luck with them.
ford1386
Gardners, PA
306
I know champion plugs are a piece of crap but I figured if I'm gonna put a couple plugs in just to read color I'd just buy cheap ones but I'm not seeing a color change in them. But the ar134 plugs that have been in the motor since the rebuild are black but the 2 new champion plugs won't change color.....
