Having an Issue with front springs after lifting...brand advice on springs
geck0
Cincinnati
FORD
So my rear of my 86 BII is sitting at 21.5" from axle center to fender and front AFTER 1.5" spring spacers is sitting at 17.5" I'm thinking my front springs are shot. So i've been looking at leveling springs and i found a set on that auction site. They say their made by skyjacker but i'm a little sceptical..Anyone have any expereince with them?
Product Specs:
Vehicle: 83-90 Bronco II 2wd/4wd
+ High-strength Softride lift coil springs
+ Powdercoated to resist corrosion
+ Preset and formed from 5160H chromium alloy to ensure a higher tensile strength and longer life
ß This product has the full Skyjacker product warranty
Top Gun Customz is an Authorized Skyjacker Dealer. We sell a full line of the Skyjacker products as well as many other Top Manufactures.
MY other issue is when i back up to park the CAMBER pulls in raising the truck in the front like 2-3"???? then when i roll forward back down it goes... All the ball joints are new, shocks are new all steering new only thing old are the pivot bushings and radius arm bushings.:icon_confused:
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
That happens because your wheel alignment is out of whack (specifically the toe alignment, sounds toed-out by your description).
I'd recheck everything before concluding your springs are incorrect.
However Skyjacker does make very good coil springs.
geck0
Cincinnati
FORD
Yea I was excited to see it being skyjacker but i was concerned if they REALLY were skyjacker or just claiming to be..
geck0
Cincinnati
FORD
YUP!!! went out on lunch with some tools BII was toe'd out pretty bad, adjusted them in a couple turns and now no up and down going back and forward AND I GAINED 2'' in the front end!!!!! Drives MUCH better!!!! Thanks for the advice guys once again you saved mah BUTT!! (AND BUTT i mean wallet)
