Have 5.0 swap questions
Iceman21
Brewster, WA
Bronco 2
2.8L (soon to be 350) and 2.9L
I have a 80's something 302/c6 combo out of a station wagon. It's carbed. The c-6 is 2wd...
I have an 84 b2 I wanna swap it into.
What t-case would bolt up, and something I havnt seen anywhere is what DRIVE LINES do you use..?? I just need info
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
You are not going to be able to bolt a t case to that c6, you are going to need to convert it to 4x4 or big a different one. Most full-size t-cases will bolt up, but not all will fit between the frame rails. Popular ones are, np205, np208 and some use a bw4406. I tried to use a bw4406 in my 85 b2 but it was just too big. Last, what do you mean by drive line? I am using a 80's 302, a M5OD-R2 out of a 01 4.2L f150 and an np205 with stock axles. I haven't figured out driveshafts yet. Hope that helps.
Sent from my SPH-L900 using Tapatalk 2
Iceman21
Brewster, WA
Bronco 2
That's what sayin, what the heck do you use for drive shafts? Do you just have to drop some coin and Get custom ones? And well crap... Can I modify the c6 to accept a np205? I would like to keep it if possible
