Has anyone replaced the timing chain tensioners?
Saddle Tramp
748
Florida
If so, what mileage did you change them at?
I have a set of Cloyes and trying to figure out when to do it.
Roert42
5,012
Kintersville, PA
Ranger XLT
4.0 SOHC
I replaced mine at 70K on one truck. The other truck I bought with 200K on it and I changed them when I bought the truck.
Plan to do it when you have to change the oil anyway, since you have to drain the oil to take them off.
Used Cloyes on both I think both of them have at least 30K on the tensioners now w/o issue.
The 2003 is a stock engine, and it took about an hour. Had to pop the upper intake loose to get to the one on the front. Much easier then the suggestion of removing the thermostat housing. No messing with fluids.
The 2011 has a supercharger and it took about half hour to change them since I could get at the front one with out removing anything.
Saddle Tramp
748
Florida
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Recommend renewing the OilPressurized TimingTensioners every 8years\75kMiles.
Got into the habit of spraying a little CarbCleaner into the OilSupply galleys when I change these tensioners,
(believe this may help to clear out any old oil sludge),
then start & idle the engine for a 10~15min, checking for oil leaks. if no leaks & tensioners+guides sound ok, then change the Oil+Filter.
Click here for more on changing the OilPressurized TimingTensioners.
Saddle Tramp
748
Florida
Thanks for the reply and link.
I don't know why, but I was thinking that a ton of oil would pour out when changing the bottom one. (Forgetting that most would be in the pan.)
Saddle Tramp
748
Florida
I'm starting to over think this and wondering if I should also do a Marvel's Mystery Oil treatment too.
Or will that just cause more sludge?
gw33gp
Ham Radio Operator
538
Costa Mesa, CA
4.0 SOHC
33"
I changed the first one at 100K miles and the second one at 250K miles. I always use OEM parts when I can, and OEM tensioners were available. Both times the old tensioner were still good.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Fair enough haha.
I'm trying to round up a pair of tires to ruin with an extravagant burnout. Found one in the middle of the road a few years ago... just need another one.
Billy Cranston
21
San Diego
31"
~ Certified Glue Eater
damn y'all are throwing down the gauntlet!! If only I saw this before I blew up my rear diff, you can burn rubber even on the N/A 4L.
Gotta to baby it for a while (at least until the 500 mile break-in mark :icon_thumby:)
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
:popcorn::popcorn::popcorn: Who can do the best burn out????
I wouldn't really consider myself to be that competitive. In fact, I stopped playing school hockey after 8th grade because I knew the HS team coaching and overall atmosphere was more centered after wins than it was the FUN.. and that's why I played.
Burnouts however.... ha. I'll blow up my motor and burn down my house if that's what it takes to be victorious.
