Has anyone done this?
dgarner08
Has anyone swapped a ranger body on a full size bronco or f150 frame? I wanted to do a sas but i saw Brian Swanson's truck in the picture galleries and i started thinking that it would be just as good (i think...correct me if i am wrong) to swap the ranger body on the full size frame. I would use a 1970 something frame with a 1984-1988 ranger body... Brian used a 1985 4x4 ranger and a 1979 4x4 bronco frame.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,871
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
DaveR had a project like that going, shoot him a PM.
Guy who used to run a body shop near me had a Ranger body on an early Bronco frame, as I recall he still had to shorten the frame a few inches. It looked more normal because the axles aren't so wide.
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
My buddy built a full size bronco with a Ranger Ex cab and tube bed. Still dont have pics of it. Frame was 80's somthing with a 92 cab.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
I remember someone put an Explorer body on an F150 frame. Looked really sweet, don't remember who it was though.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
if you are talking about the green gen1 explorer, that was a 79 F-250 with a 300 six ...... which is why he did it. I was easier than swapping in the 300 six.
samsonitesamsonite
Bellingham, Wa
Jeep
2.5
I want an I6 in my ranger.... yeah DaveR did that exact swap of a ranger body on a fullsize frame. I believe he used it for his plow truck.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you do that i want your 4.0L. 5spd, computer, t-case .... ect.......
Loanranger
4
Puyallup, Wa
1972
Ford/
Fordzuki
2.9/2.3
A little off topic, but I put a 79 Datsun body on a 76 Ramcharger chassis. Probably the hardest part was the steering, just double U-joint it and you won't have any problems.
Dave R
In the snow belt
Kaiser
I USE it as a plow truck. Present tense, as in it's still alive and kicking. I really need to get back to work on it someday.
It's not an overly complex swap to do but, it does require considerable labor. Reasonable welding skills are a definite plus.
Mine is a '90 short bed Ranger, a former street truck of the month here at TRS :haha: , on a '79 Bronco's running gear.
dgarner08
Could i use a F150 frame and running works under a 1985 regular cab ranger. I would put a flat bed on it just to simplify things a bit. also i would probably shorten the frame...is a older bronco and F150 about the same width? If i could put my ranger on a F150's running works i could have a little ranger with 8-12 inch lift with a 400 or 460:shok::yahoo:
