harmonic balancer removal
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
At least it was an easy, cheap fix :icon_thumby:
SVT
gene55
Couldn't have done it without the help I received on this forum. Thanks for all the info.
txgocartB3000
San Marcos, TX
Mazda
Hey, I make those kind of mistakes all the time.
You think we might be related?
Ray
RemMax
Indiana
ranger
You need to put the crank bolt in and thread it two turns. Then get use a pulley puller. Place on the crank bolt. The hole that the bolt goes in. Is only big enough for that bolt. I snapped my balancer trying take it off. So use the crank bolt to push and pull off of.
I have this same balancer/pulley and don't know what type puller your talking about
How do you grad it in the center with no holes to attach the puller to???
black_demon69
142
AZ
4.0l
It should just slide off after crank bolt is removed without a puller...
sgtsandman
Aircraft Fuel Tank Diver
12,660
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
It might be rust locked in place. If you have to resort to a puller, use one with at least three pulling arms if you can. Just two arms is harder to work with and has more potential of damaging the pulley.
black_demon69
142
AZ
4.0l
Also be careful not to pull pulley of of rubber ring on the damper or you will need to replace it
RemMax
Indiana
ranger
It finallyame off
Good dose of PB. Laster and about a hour to set & soak inworked wonders
I used a small pry bar on left and tapped with brass hammer on right and Walls, slid right off
Thanks for the help, thought I had missed something on it
P.S. the balancer bolt on mine came right out using my SnapOn impact
Seems most people have trouble with that but a good qualityimpact works wonders. ??
