Hagan's '86 Ranger build!
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
Ok I got my tank mounted. I used a '84 Bronco 2 tank. It is a carbed tank so it will have just a single pickup and no return. I mounted it behind the rear axle where it would go in a b2.
I made a crossmember.for the front out of some square tube I had laying around. I bolted it to the frame where the front of the tank will sit. I then drilled 2 hole holes and welded 2 long bolts through the holes. I fit the tank again and welded a piece of angle iron on the back of the crossmember so the lip of the tank hits it and holds it down
I had to rebend the tank straps (I got them from a b2) and move the strap mounts on my frame.
BronKitis
Spanaway, WA
2.9L
That's a Purdy tank!
Hagan
11
Salem, OR
2.3
Yeah it sure is!
Anyway, I'm using a 302 now. The 351w I had was in bad shape and needed a rebuild
BronKitis
Spanaway, WA
2.9L
That's a Purdy motor! I've got a lead on another 351 that I'm going to build while I enjoy the rather tired one I put in. Your rig is looking good! Keep up the good work.
Hagan
11
Salem, OR
2.3
I'd love to have a built 351w! I now have 3 302 blocks and a 351w lol
If I built a 351w I'd stroke it to a 408. But building an engine wasn't in the cards for me right now. I needed something that ran good.
Last night I got it fired up! Probably for about 10 seconds at 11:00pm lol. My neighbors just had a baby a couple days ago and I felt like such a dick with open headers. That's why I barely ran it. It took about 6 mins from the time we were ready to crank to running. On a carb I've never used, a carb I just rebuilt, a distributor I've never used, and an engine I've never heard run. Not too bad!
I've got A LOT more work to do. I'll update as much as I can.
merch
shreveport louisiana
351w
Nice work on the tank,i did the same tamk swap but I used a skid plate from the bii on top of the frame and straps on bottom to squeeze the tank and hold it on place. I also use a 351w.......not an easy thing to fit lol
Sent from my DROIDX using Tapatalk 2
merch
351w
Whered you get transfercase mount? It would be prfect for my 205
Hagan
11
Salem, OR
2.3
I'm actually running a 302 now. But a 351w is a little tougher to fit.
I got the 205 mount from behemoth drivetrain. Its the same place I got my doubler (strongbox) from. It seems well built and it was easy to modify to my needs. It replaces the output shaft seal and retainer thing and bolts back in place.
I can get more pics if you want?
Hagan
11
Salem, OR
2.3
I had to move my radiator into the core support because the upper radiator hose pointed into the alternator pulley. It had about 3/4" clearance. It wasn't going to work.
I cut out this much. I rewelded the captive nuts and plates back to the core support so the radiator would mount to the core support like how the factory did.
Rewelded the pieces back for a better look
Radiator tucked in.
Clearance...
Hagan
11
Salem, OR
2.3
I got the new sending unit in my tank and the lines plumbed. I got my fuel pump mounted and bed back on.
I am using the sending unit out of an '84 Bronco II. Its new though. I ran hard lines along the frame rail. Its 3/8" brake line and I'm using fuel injection hose. Its supposed to withstand todays fuels better.
I also built a new track bar mount. I lowered it and moved it back for better clearance.
simonbrld
Nice 86, that's something I don't see everyday. Good to see your updating.
Hagan
11
Salem, OR
2.3
I got a little more work done. I got my zf5 clutch working and I got my radiator and fan installed.
My factory clutch hydraulic was ruined so I needed a new one. I removed it by pressing out the roll pin at the base of the clutch master cylinder. I was going to use the original line off a '94 F150 (I parted one out but kept that) but the fitting was different.
I made a trip to the junk yard and couldn't find the line that matched mine. I got a line off a '88 Ranger. Its short and has the right bends. In order to make it fit my clutch master cylinder I decided to just buy the clutch master cylinder for an '88 Ranger. It was a simple bolt on deal.
Original line on top with a smooth end. The new line on bottom with an angled end
A look at the original Ranger line connected to the zf5
New clutch master cylinder
New vs old
Here is my radiator and fan setup. Radiator is from a first gen explorer. Fan came off a 90's Jag with a v10. Pulled it out of the junk yard for $10. It is a pusher fan. Mounted with scrap aluminum to the factory mounting holes on the fan.
Hagan
11
Salem, OR
2.3
Worked on the Ranger a little more. Decided to pull the 302 to build a new engine cross member. Spent hours looking at it. Im not very happy with it but it will work for now. Basically I had to trim it because my 302 is so far forward because of my zf5.
It's the stock crossmember with 3/8" plate welded on the inside.
Sitting tall and pretty!
Grunizzle
01/2013 OTOTM Winner
Albuquerque, NM
4.0L V-6
So that's as far back as the zf5 will go? Will you be able to get the upper bellhousing bolts? I don't remember but did you clearance your tranny tunnel and fire wall?
Hagan
11
Salem, OR
2.3
I had to beat the body bond lip back on the tunnel. I only cut the upper section out of the tunnel and left the firewall alone. I also had to cut these "ears" off the sides of the trans. I can use a ratchet and socket to get the upper two bolts out from the engine bay.
A body lift would have helped a lot.
